FS: Hatz Project - Needs a Home - Make Offer
mauleowner
Post by mauleowner »
Hatz Classic Project – Hatz fuselage, main gear legs, Matco tail wheel, tail feathers and some fuselage formers. Over 4350 hours on builders log for this project between June of 2010 and December of 2011. Two Technical Counselor Visit Reports during the build. This project has not been primed. A light rust layer is apparent on 2/3’s of the fuselage. Will need blasting and priming as soon as possible. To see more photos, go to the EAA Builders Log Site https://eaabuilderslog.org and search for projects in the 75754 zip code. Asking $4500 or best offer.
Project is located at the Mineola-Wisener Airport (3F9) 22 miles northwest of Tyler, Texas. PM with questions or call Jim at (903)292-7625
You will need to use the scroll bar to view properly, I don't know how to resize pictures.
Jimmy Chadwick
Stinson 108-3 165 Franklin
RV-7 I0-360 200HP
http://www.mykitlog.com/Chadwickj/
